Copy/compare folder
Prince
Copy/compare folder
Sub folder question
Hi
I have read a lot of post but I think this my request nobody ask to this forum for a possible solution.
This is my request if possible. I have this scenario:
c:\example
in this folder I have this subfolder
c:\example\carl\- 01 -
c:\example\richard\- 02 -
c:\example\helena\- 03 -
c:\example\stephan\- 02 -
c:\example\morgan\- 04 -
c:\example\mary\ - 03 -
I need to create a script for compare/copy only folder with subfolder "- 02 -"
Final result will be:
The other folder name must be exclude
Is this possible?
Thanks for an help
Prince
Re: Copy/compare folder
That's sound ambiguous to me.
Do you want to
- copy only folder with subfolder "- 02 -"
- or copy only the subfolder "- 02 -"
Or are these the same, i.e. is there always only one subfolder?
Do you want to
Need to copy folder (and file into it) with subfolder (and file into it)
There's no magic way to implement such special task.
You have to write a script that identifies the folders you are looking for.
It is easy e.g. with PowerShell and WinSCP .NET assembly.
https://winscp.net/eng/docs/library_powershell
Use:
- Session.ListDirectory to enumerate all folders
- Session.FileExists to check an existence of the - 02 - subfolder
- Session.GetFiles to download them
https://winscp.net/eng/docs/library_session_listdirectory
https://winscp.net/eng/docs/library_session_fileexists
https://winscp.net/eng/docs/library_session_getfiles
