issue on auto syncronization
dados77
Hi.
I want to automatically syncronize file in a directory to a remote one when in sourcing directory a file has been added.
If I make syncronization manually all work fine, instead if I startup automatic syncronization same file is transferred two time at the same time stamp.
Re: issue on auto syncronization
What do you mean by "startup automatic syncronization"? Do you use this?
https://winscp.net/eng/docs/ui_keepuptodate
