Unable to add to Visual Studio for AWS Lambda project
Hi there,
I'm fairly new to using Visual Studio, but I'm trying to create a program for use with Amazon Web Services' Lambda service. According to AWS docs, you need to use .Net Core, which I am doing. When I try to add WinSCP as a NuGet package, I get the following error.
Package WinSCP 5.9.4 is not compatible with netcoreapp1.0 (.NETCoreApp,Version=v1.0). Package WinSCP 5.9.4 supports: net (.NETFramework,Version=v0.0)
One or more packages are incompatible with .NETCoreApp,Version=v1.0.
Is there a way to make this work?
Thanks,
Jason
Re: Unable to add to Visual Studio for AWS Lambda project
I'm afraid you cannot make it working with .NET Core. WinSCP .NET assembly in not a native .NET framework assembly. It relies on an external console application.
I'm still able to include both the dll and the exe and don't expect any problems with the dll trying to use the exe. I just don't follow why the NuGet package is saying it conflicts with .Net Core.
Because I assume that .NET core cannot run Windows binaries. It would not make sense.
