powershell synchronize with changing file extension while downloading.
ivanyeung
hi
i want to synchronize the local path from the remote ftp server.
on the remote server,there are jpg files,i get success with the standard synchronize method.
however,how can i changing the file extension from .jpg to let say .txt while downloading and rename it to .jpg after downloaded?
this is my scripts
try
Protocol = [WinSCP.Protocol]::ftp
HostName = "XXX"
UserName = "XXX"
Password = "XXX"
try
# Will continuously report progress of synchronization
$session.add_FileTransferred( { FileTransferred($_) } )
# Connect
#Define the file type to downloaded
$transferoptions= New-Object WinSCP.TransferOptions
$TransferOptions.FileMask = "*.jpg;*.txt"
# Synchronize files
$synchronizationResult = $session.SynchronizeDirectories(
[WinSCP.SynchronizationMode]::local, "d:\downloads\pic\", "/pic/", $false,$false,1,$TransferOptions)
# Throw on any error
$synchronizationResult.Check()
finally
# Disconnect, clean up
$session.Dispose()
catch [Exception]
Write-Host ("Error: {0}" -f $_.Exception.Message)
Anonymous wrote:
thanks for your reply
however Transfer to temporary filename is supported with SFTP protocol ?
OK, you are using FTP, right?
Then you would have to do everything programmatically (enumeration of files, finding differences, transfer to temporary file name, rename).
