file name escaping for windows?
vlad
tried to edit file 'ifcfg-eth0:0' on remote server by pressing F4, and it didn't work (I guess because windows didn't like the colon in the file name). Perhaps some sort of workaround can be established in the code?
p.s. Martin, I wonder is there a new version of FAR plugin coming out shortly? if "yes" - what are the features we can expect for?
thanks again for your work! :)
-- vlad
Re: file name escaping for windows?
In WinSCP plugin you cannot edit file with name not allowed on Windows. I haven't found a way how to solve that. The reason is that FAR expects the temporary local filename to be the same as the one shown in file panel. And this cannot be fulfilled. Note that WinSCP application allows editing such files.
I do not know yet. Do you miss some specific functionality?
vlad_
features....
Martin:
thanks for the reply.
the only features I'm really missing are notorious keep-alive-while-in-editor and possibility to restore connection with chdir to the path on remote server where I was right before connection was lost. I asked about both here on the forum, but you said that due to the bugs in FAR API it's not possible to implement. Btw, did you try with one of the recent builds of FAR? https://www.farmanager.com/
minor thing that (imho) would not hurt to do is adjust options names and their hotkeys in copy/move dialogs to the same as FAR uses in standard copy dialog - it's kinda irritanting to have different names and hotkeys for very similar actions in WinSCP plugin.
Other than that, it's a great plugin that saves me and several buddies I work with a lot of time - thank you very much! :)
--vlad
Re: features....
I'm sorry if I wasn't clear enough - I meant "option" WinSCP offers to choose from on the confirmation dialog, when file is already exists on the destination panel.
Winscp has (I marked hotkeys with caps):
Yes | alwaYs | No | cancel | aPpend | neWer only | nO (all) | yes (aLl)
Compare to the standard FAR's dialog:
Overwrite | All | Skip | sKip all | aPpend | Cancel
I think using FAR's names would be logican and make life little easier ;)
-- vlad
Re: features....
The bugs are still present.
Good idea. I will se what I can do about that.
