session.FileExists hangs when no file but returns 'true' when when there is as expected.
supermankelly
Essex
I'm using VB .net within Visual Studio but the FileExists hangs and does nothing when no file exist on remote SFTP server. ie it doesn't receive a 'false'. PutFiles and GetFiles seem fine.
If session.FileExists(toFile) Then
    session.RemoveFiles(toFile)
End If
Also MoveFiles also hangs if the file moved to exists. Is there a overwrite for this? Or at least return an error code so it can be handled.
And RemoveFiles hangs if no file exists to remove.
Just used this sites exact sample as provided and this hanged when the GET file didn't exist???
    Public Function Main() As Integer
        Try
            ' Setup session options
            Dim sessionOptions As New SessionOptions
            With sessionOptions
                .Protocol = Protocol.Sftp
                .HostName = "xx-xxxx.xxx-xxx.xxxx"
                .UserName = "xxxxxx"
                .PortNumber = "8822"
                .SshHostKeyFingerprint = "ecdsa-sha2-nistp521 x xx:ex:xx:fe:xx:bc:ex:cx:xx:xx:xx:xx:cx:xc:xb:xx"
                .SshPrivateKeyPath = "C:\xxxx\xxxxx\Documents\private_key.ppk"
            End With
            Using session As New Session
                ' Connect
                session.Open(sessionOptions)
                ' Download files
                Dim transferOptions As New TransferOptions
                transferOptions.TransferMode = TransferMode.Binary
                Dim transferResult As TransferOperationResult
                transferResult = session.GetFiles("\Test\Outbox\Pricelists\xxxx-pricebooks-global.xml", "C:\Users\Documents\xxxx-pricebooks-global.xml", False, transferOptions)
                ' Throw on any error
                transferResult.Check()
                ' Print results
                For Each transfer In transferResult.Transfers
                    Console.WriteLine("Download of {0} succeeded", transfer.FileName)
                Next
            End Using
            Return 0
        Catch e As Exception
            Console.WriteLine("Error: {0}", e)
            Return 1
        End Try
    End Function
Cheers
Andrew
supermankelly
Looks like this isn't isolated issue (https://winscp.net/forum/viewtopic.php?t=15326) with FileExists hanging when returning an error condition. This works on another of our SFTP servers. So I will post up the differences of the two shortly once our admin sends me a summary.
Re: session.FileExists hangs when no file but returns 'true' when when there is as expected.
