How to redirect terminal output of winscp3.com to file
TN
Hello there I got a question, is it possible to redirect the output of winscp3 command shell promt into file? I would like to generate files with the content of my directories. I tried to use ls > list.txt, but it doesn't work win winscp3.com command shell. Can anybody help?
Re: How to redirect terminal output of winscp3.com to file
You can only redirect whole session:
winscp.com /command "open user@host" "ls" > output.exe
Kaydet81
I am trying to call WinSCP from a Visual C++ 6 program using CreateProcess. The resultant command line is something like:
"C:\Program Files\WinSCP3\WinSCP3.com" /script=C:\TEMP\SCR1.tmp > C:\TEMP\SCR2.tmp 2>&1
This works fine from a command prompt but does not work well from my program (with appropriate escapes for "\") or the Windows "Run" dialog. The Run dialog produces the same results as my program - I get a console window that prompts for a user name, shows some errors, and does not redirect output.
For context, my VC6 program's purpose is to get files from source control (PVCS) and push them out to the server with WinSCP in a seamless fashion. I need to capture output to know the nature of errors that may occur.
Thank you.
I'll try that. I never did.
Re: Logging terminal output
farmerBill wrote:
winscp.com /command "..." "..." > out.txt
does not work. Any ideas?
And what does it do? Where do you run the command from?
farmerBill
(VISTA .bat file):
@echo off
start "cmd.exe /A WinSCP" "C:\Program Files\WinSCP\WinSCP.com" /command ^
"open student@localhost" ^
"cd /home/student/asas" ^
"pwd" ^
"put abc.txt" ^
"ls" ^
> hw3updat.scriptlog
farmerBill
PS
Sorry I didn't answer your post completely. It creates an empty file. The FTP commands work ok. Same behavior with "CMD.EXE" omitted.
