PerfectSolution
The data area passed to a system call is too small!
Hi,when i start Winscp.exe i get this message "The data area passed to a system call is too small!" I would be really happy if someone help me.
PerfectSolution
The data area passed to a system call is too small>
martouf
System memory (RAM) exhausted?
PerfectSolution
Nope,i hvae 2gb available. OS : Windows 10 Pro.
martouf
There's 'system' as in all memory for any purpose and there's 'system' as in kernel memory.
Using PoolMon to Find a Kernel-Mode Memory Leak
https://learn.microsoft.com/en-us/windows-hardware/drivers/debugger/using-poolmon-to-find-a-kernel-mode-memory-leak
Site Admin -
- 43,055
- Prague, Czechia
Re: The data area passed to a system call is too small!
Thanks for your report.Hi,when i start Winscp.exe i get this message "The data area passed to a system call is too small!" I would be really happy if someone help me.
- Guest
Hi,i can`t see your email.Thank you.
Site Admin -
Did you register and log in?Hi,i can`t see your email.Thank you.
PerfectSolution
Solved
The problem was virus. .bat file in windows foleder.
- bdmacl
- 1
- Colorado
I'm having the same problem with the paid version from the MS Store
I can run the classic version just fine. I decided to "donate" by purchasing on the MS Store based on your recommendations. I can't run the app because I get that same "The data area passed to a system call is too small" error. I have 32GB of Ram, almost all is free, I reboot cleanly and still can't run the paid version. Additional info: C:\Program Files\WindowsApps\MartinPikryl.WinSCP_5.13.7.0_x86_tvv458r3h9r5m\winscp.exe
Running Win10 Pro, latest updates applied.
Site Admin -
- 43,055
- Prague, Czechia
Re: I'm having the same problem with the paid version from the MS Store
Thanks for your report.I can run the classic version just fine. I decided to "donate" by purchasing on the MS Store based on your recommendations. I can't run the app because I get that same "The data area passed to a system call is too small" error. I have 32GB of Ram, almost all is free, I reboot cleanly and still can't run the paid version. Additional info: C:\Program Files\WindowsApps\MartinPikryl.WinSCP_5.13.7.0_x86_tvv458r3h9r5m\winscp.exe
