I cannot delete any folder
Beemer
Scotland
I'm using version 5.9.4 and cannot find a way to delete remote folders even if they are empty. Can someone help me
Ian
Beemer
Sorry if I posted too early. I have found that if I drag a folder to the recycle folder it effectively deletes it. However I'm curious why standard delete button or menu delete item is not provided?
Ian
WolfgangSau108
Removing Files and Reloading in Winspc
I inadvertently removed files from winspc public_html and need to purge the site and reload my website to be transferred to hosting service. Can you give advice as to what steps I need to perform to clear the site and then reload the website I created in Micrsoft Fron Page. Site and uploads worked well for 5 years and only in the last few days through erros of my own am I having problems. I am a novice user.
There is Delete button on the toolbar, in the Files menu, in the context menu, everywhere.
Re: Removing Files and Reloading in Winspc
Sorry, but that's a way too broad question. And probably not about WinSCP anyway.
