Is it possible to switch local with remote view
saudiqbal
Is it possible to put remote window on the left and local on the right. I have been using ftprush for almost 15 years and used to that view, if not no biggie.
davidfuchs42
Thank you spent 20 minutes on this.
I was about to uninstall this then found this thanks. Everything else has local on the right and outside on the left
