Transferring files with long file names
Hi I am having issues with long file names and couldn't find reference to any limits in the documentation.
when I try to transfer a file with a long filename I get the following error message:
No such file or directory.
Error code: 2
Error message from server: No such file
Request code:
has anyone had similar issues?
If I change the filename to something shorter it seems to go ok..
Re: Transferring files with long file names
How long is the file name? What operation are you going to use? What is your SFTP server? Can you post a log file?
