unable to use winscp in windows task scheduler
siddhant
I am new to WinSCP. I am trying to schedule a normal put job using winscp. I have cretard a .bat file using below query.
winscp.com /log=F:\test\winscp.log /script=sftp.txt
In sftp.txt i have used below query.
option batch on
open NFSFTP
put F:\test\BSCC.txt /cs/test/
EXIT
When i execute the batch manually the file was delivered to SFTP but after scheduling the task in windows task scheduler the job can't send the file to SFTP.
Please advise.
siddhant
For your information i could not find the .ini file in the system. Is it causing the task scheduler job not to succeed. I have tried every step but failed. Should I create a new .ini file?
Thanks.
siddhant
I am still struggling with this. In a forum i found that if you are using private key you need copy the finger print to sftp server keys and you need to explicitly add private key in the script. Is it the right way to do the automation. Please help.
Yes. That's the recommended way.
The easiest is to have WinSCP GUI generate a script template for you.
https://winscp.net/eng/docs/ui_generateurl#script
See also
https://winscp.net/eng/docs/faq_scheduler
https://winscp.net/eng/docs/scripting#configuration
siddhant
Hello Martin,
File(s) > File Names > Generate File URL tab has been greyed out for me. How to activate this option?
This has nothing to do with this thread. Anyway, the command is disabled, when you have no file selected (or when the remote panel is not active).
