can i gain some credential-data out of a filezilla xml-ini data set
openSuseman
hello dear experts
while finding out the correct settings:
can i gain some credential-data out of a filezilla xml-ini data set?
is this possible?!
openSuseman
after importing the winscp-ini-file i tried to connect to the server
error number2
winscp could not find the protocol-file in the path
[path to a folder on the ___old___notebook___where the files formerly where stored]
what can i do.
do ihave to set up the paths new
love to hear from you
What is "protocol-file"?
Can you post an exact error message? Or even a screenshot?
Is this follow up to the previous question? Or a new question? Because previously you have asked about import from FileZilla. While now, you are asking about "importing the winscp-ini-file".
