Deleting Empty Directory of FTP Server
This is a great system, and I have done pretty much everything that I have wanted, but struggling, one last point.
I'm trying to delete an empty directory with an automated process, and not having any luck.
I can use the command prompt FTP and remove the directory with the command:
ftp> ls Trinity_00076_20170204_194014
200 Port OK
150 Opening data connection
226 Transfer complete
ftp> rm Trinity_00076_20170204_194014
250 Directory removed
200 Port OK
550 S_dosFsLib_FILE_NOT_FOUND
<group name="rm -- "/ata0:1/Echelon/Trinity_00076_20170204_194014/"" start="2017-02-06T18:47:49.269Z">
<rm>
<filename value="/ata0:1/Echelon/Trinity_00076_20170204_194014/" />
<result success="false">
<message>Internal error fz#removedir (0010).</message>
<message>Error deleting file '/ata0:1/Echelon/Trinity_00076_20170204_194014/'.</message>
</result>
</rm>
<failure>
</failure>
</group>
Any ideas on what could be happening? I am using the following line of code to do this:
var result = session.RemoveFiles(GetDirectoryName(file));
With the result of result.IsSuccess = False
Thanks - Wil
200 Port OK
200 Port OK
<rm>
</result>
</rm>
<failure>
</failure>
</group>
Thanks - Wil
