scripted sync with mirroring function
timom
I try to mirror source and destination with the scripted winscp program. The problems at the momet were that if I change a file on the destination I can not replace it with the sync function.
Are there any chances to do?
Timo
Re: scripted sync with mirroring function
Why? What is the problem?
timom
The problme is as possible:
1. sync source -> destination
2. change a file on the destination
3. sync source -> destination
=> the manual created file on the destination do not changed
Of course, because it is newer than the source one.
timom
Is it possible to get an exact copy from source to destination?
That's what "get" and "put" does. Of course it will transfer everything. Or you may set "size" as synchronisation criterion in GUI.
