Create folder from file name
nickodemos
Was wondering if it would be possible to have a script that would create folder based on the file name.
EG I would click on BSD.iso and choose the script to create a folder in current folder with the name BSD and move the BSD.iso into the newly created BSD folder.
I did a quick search and found nothing asking this.
nickodemos
Sorry I should have thought to put that in.
Yes. On the remote folder I would right click on a file to bring up the context menu and have an option under 'Custom File Commands' that would create a folder and move the file I clicked on into the newly created folder: root/BSD.iso >> root/BSD.iso/BSD.iso.
Only thing better would being able to remove the extension in the folder.
root/BSD.iso >> root/BSD/BSD.iso.
I'm no *nix expert, so there can be a better solution, but should should do:
filename="!" && mkdir "${filename%.*}" && mv "!" "${filename%.*}"
