Error Loading file using 'UTF-8' Encoding
cogdellj
New York
I get the following error when sending a simple text file UTF-8 encoding to a SFTP site then trying open it. [/img]
Re: Error Loading file using 'UTF-8' Encoding
What happens after you click OK?
Does the problem really occur only after an upload? Can you open the file from a local folder?
Hannibal
I had the exact same problem. It was because the display font of the internal text editor had somehow turned to null.
Options > Preferences... > Editors > Internal editor
I set an appropriate font and then it started working.
You may want to check it out first.
