Error Registering 32 Bit Assembly
madwizard78
So. Cal
When I attempt to register the 32 bit option I get the error message:
RegAsm : error RA0000 : Unable to locate input assembly 'c:\windows\system32\WinSCPnet.dll' or one of its dependencies.
The command I run is:
%WINDIR%\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe c:\windows\system32\WinSCPnet.dll /codebase /tlb:WinSCPnet32.tlb
But when I do the 64 bit version, it works properly:
%WINDIR%\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe c:\windows\system32\WinSCPnet.dll /codebase /tlb:WinSCPnet64.tlb
This is on an older server (windows Server 2003 R2) but 2 other servers it worked. I did just notice that the one not working is x64 Edition. Could that be it and any ideas?
Thanks very much in advance.
madwizard78
Well I'll reply to my own. I got it resolved. I moved the file from the c:\windows\system32 folder into c:\windows\syswow64 and registered it with it there and it had no issues.
Re: Error Registering 32 Bit Assembly
On 64-bit systems, the c:\windows\system32 is a magic folder that cannot be access by 32-bit applications.
