Cannot tackle problem "Nothing to Synchronize"
EddieChan
I am new to WinSCP and even WinSCP script. I tried to run the script as follows.
option batch on
open sftp://[username]:[password]@[ftp-server]:222/ -hostkey="ssh-rsa 4096 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
synchronize local D:\Eddie\work2 /_V6_/b5/media/presskit
And it always return "Nothing to synchronize" and my local directory is empty.
Attached is the log file (I replace all sensitive data with xxx). Please forum administrator can help me. Thanks.
Regards,
Eddie
  • log2(forum).txt (86 KB, Private file)
Description: log file
Psammead
Re: Cannot tackle problem "Nothing to Synchronize"
I have the same error message and problem. Is there a solution to this yet?
Thanks.
No. Your local directory contains all files that remote directory does:
. 2017-01-18 14:13:07.121 Local file 'D:\Eddie\work2\.' [2017-01-18T04:59:16.063Z] [0] excluded from synchronization
. 2017-01-18 14:13:07.121 Local file 'D:\Eddie\work2\..' [2017-01-18T04:59:16.063Z] [0] excluded from synchronization
. 2017-01-18 14:13:07.121 Local file 'D:\Eddie\work2\awards' [2017-01-18T05:00:13.254Z] [0] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\chungchichapel.html' [2011-05-30T11:01:26.000Z] [14399] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\chungchiweiyuanlake.html' [2011-05-30T11:01:26.000Z] [14357] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\images' [2017-01-18T04:59:15.770Z] [0] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\newasiapavilion.html' [2011-05-30T11:01:27.000Z] [14347] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\newasiawatertower.html' [2011-05-30T11:01:27.000Z] [14414] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\news_links.html' [2011-05-30T18:59:02.000Z] [13622] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\photo_gallery.html' [2011-05-30T11:01:27.000Z] [25919] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\shawcollegesign.html' [2011-05-30T11:01:28.000Z] [14361] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\shawkuomouhall.html' [2011-05-30T11:01:28.000Z] [14345] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\statistics' [2017-01-18T04:58:38.781Z] [0] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\transport' [2017-01-18T04:58:39.936Z] [0] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\transportation.html' [2011-05-30T11:01:28.000Z] [13850] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\unitedsculpture.html' [2011-05-30T11:01:28.000Z] [14348] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\unitedwatertower.html' [2011-05-30T11:01:28.000Z] [14412] included to synchronization
. 2017-01-18 14:13:07.122 Local file 'D:\Eddie\work2\universityentrance.html' [2011-05-30T11:01:28.000Z] [14356] included to synchronization
. 2017-01-18 14:13:07.123 Local file 'D:\Eddie\work2\universitylibrary.html' [2011-05-30T11:01:29.000Z] [14368] included to synchronization
. 2017-01-18 14:13:07.123 Local file 'D:\Eddie\work2\universitymall.html' [2011-05-30T11:01:29.000Z] [14349] included to synchronization
. 2017-01-18 14:13:07.123 Local file 'D:\Eddie\work2\universitysciencecentre.html' [2011-05-30T11:01:29.000Z] [14399] included to synchronization
. 2017-01-18 14:13:07.123 Local file 'D:\Eddie\work2\video' [2017-01-18T04:58:38.659Z] [0] included to synchronization
Psammead
Here is the file, thank you.
  • synclog3.txt (11.43 KB, Private file)
You have "Existing only" synchronization option enabled in global configuration:
> 2017-01-31 13:49:28.457 Script: synchronize local -preservetime -delete D:\nsccScratch /scratch/users/astar/ihpc/cheahwl/crys/and-lev/fmix60
< 2017-01-31 13:49:28.458 Script: Using configured synchronization options different from factory defaults.
< 2017-01-31 13:49:28.458 Script: Comparing...
. 2017-01-31 13:49:28.458 Collecting synchronization list for local directory 'D:\nsccScratch' and remote directory '/scratch/users/astar/ihpc/cheahwl/crys/and-lev/fmix60', mode = Local, params = 0x7 (Delete, NoConfirmation, ExistingOnly)
In general, you should use /ini=nul switch to isolate the script from GUI configuration:
https://winscp.net/eng/docs/scripting#configuration
https://winscp.net/eng/docs/guide_automation#script_file
Psammead
Thank you - that solved the problem! Can't think how I missed that.
