Keep Time when tranferring files
TheSeiko
WinSCP 5.9.3 (Build 7136)
Option to keep time is checked in preferences and in the connection target properties.
using winscp as a batch job
data and time of the uploaded files are changed to transfer date and time.
was working with 5.7.7 (build 6257)
Windows 10 Professional
Protocol: ftp
open target01
lcd C:\OCRVideoReader\x_infoscreen\
put -delete *.jpg -resume
put -delete *.xml -resume
close
open target02
lcd C:\OCRVideoReader\x_metacommunication\
close
open target03
lcd C:\OCRVideoReader\x_observer\
close
Re: Keep Time when tranferring files
Please attach a full session log file showing the problem (using the latest version of WinSCP and if possible even using 5.7.7).
Log Transfer01
Log Transfer02
Files after FTP
for example:
File: '1484606814552.jpg' [2017-01-16T22:46:54.710Z]
after transfer '1484606814552.jpg' 17.01.2017 11:25
  • transfer01_files.jpg (349.15 KB, Private file)
Description: Files after FTP
  • _transfer02.log (42.69 KB, Private file)
Description: Log Transfer02
  • _transfer01.log (51.86 KB, Private file)
Description: Log Transfer01
old version winscp log
directory screen
  • transfer01_files_alt.jpg (280.81 KB, Private file)
Description: screen directory after upload
  • _observer.log (42.04 KB, Private file)
Description: log older winscp version
The server behaves differently in the session for 5.9.3.
While it would be strange, one of the reasons might be that with 5.7.7, you use TLS/SSL, while with 5.9.3 you are not.
I'm using TLS/SSL only with one connection with the old WinSCP. The other two are without encryption on both (old/new) WinSCP. The appearance is the same with three different connections / servers.
I'll try to recreate the settings, I've imported them from the old WinSCP.
Hmm ... I tried and updated the old WinSCP to the current version. There it is working.
Have you heard anything that a Sophos firewall could intercept the ftp communication and alter the Date / Time?
Your feedback from email:
I've talking to a IT-Sec guy responsible for the firewall.
He told me that the firewall is intercepting the ftp traffic with ftp proxy for content check. He thinks that the command for keeping date / time -
MDTM he mentioned - may not be implemented in the sophos ftp-proxy.
