WinSCP script .httpacess
FL3XI
I'm using this command to auto-sync to backup my SFTP server on my hard disk.
synchronize local L:\Backup\%timestamp#yyyymmdd% /.../html
But I always get the attached error and I can't download the .htaccess file.
Is there a workaround to always skip this file or to download it?
Best regards
Felix Förster
Re: WinSCP script .httpacess
As a quick hack, just exclude the file from synchronization:
synchronize -filemask=|.htaccess local L:\Backup\%timestamp#yyyymmdd% /.../html
https://winscp.net/eng/docs/scriptcommand_synchronize#filemask
https://winscp.net/eng/docs/file_mask
FL3XI
Solved
This wasn't a file. It was some kind of weird shortcut. I deleted it and it works now flawlessly. Thank you!
