APPCRASH WinSCP.com 4.4.0.7136 - WInSCP v5.9.3 (Build 7136) on Server 2008 R2 SP1
AvalonNYC
New York
Getting error attempting to script send SFTP using winscp.com.
WinSCP v 5.9.3 (Build 7136)
Windows Server 2008R2 SP1
Problem signature:
Problem Event Name: APPCRASH
Application Name: WinSCP.com
Application Version: 4.4.0.7136
Application Timestamp: 00000000
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.18229
Fault Module Timestamp: 51fb1116
Exception Code: c0000005
Exception Offset: 0000dee1
OS Version: 6.1.7601.2.1.0.272.7
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
command line:
D:\Scripts\SFTP\cust888>"D:\Program Files (x86)\WinSCP\winscp.com" /script="TmsSFtpscript.txt"  /xmllog=Logs\TmsSFtpSendOneFile.xml /parameter "D:\Comms\SFTP\Cust888\OUT\test.txt" >> logs\TmsSFtpSendOneFile.log.txt
TmsSFtpScript.txt is (site and key obscured for security:
option batch abort
open sftp://sftp1.obscured.com -hostkey="ssh-rsa 2048 obscured"
put "%1%" data/
close
Server/Protocol information for the remote server (site info and fingerprint obscured):
File transfer protocol = SFTP-3
Cryptographic protocol = SSH-2
SSH implementation = OpenSSH_5.3
Encryption algorithm = aes
Compression = No
Server host key fingerprint
ssh-rsa 2048 *obscured*
Can change permissions = Yes
Can change owner/group = Yes
Can execute arbitrary command = No
Can create symbolic/hard link = Yes/No
Can lookup user groups = No
Can duplicate remote files = No
Can check available space = Yes
Can calculate file checksum = No
Native text (ASCII) mode transfers = No
Additional information
The server supports these SFTP extensions:
posix-rename@openssh.com="1"
statvfs@openssh.com="2"
fstatvfs@openssh.com="2"
We have an identical script running for another remote site and it does not have a problem. The other site's Server and Protocol info (site info and fingerprint obscured) is:
SSH implementation = Sun_SSH_1.1.3
Compression = No
ssh-rsa 1024 *obscured*
Can check available space = No
The server does not support any SFTP extension.
Attached are the logs.
Thanks for all you do!
Description: XML log
Description: text log
Re: APPCRASH WinSCP.com 4.4.0.7136 - WInSCP v5.9.3 (Build 7136) on Server 2008 R2 SP1
you are not using 5.9.3, the error says 4.4.0.
Maybe you have a different version of winscp.com and winscp.exe.
AvalonNYC
New York
Hi, Martin, thanks for your post!
I previously updated WinSCP from the Update icon in the program, then ran the downloaded file WinSCP-5.9.3-Setup.exe and selected "Full Upgrade (recommended) - upgrades all previously installed components"
The upgrade successfully detected the program directory, and ran to completion. I just now did the upgrade again with logging enabled; the install log shows:
2017-01-16 08:30:53.755   Dest filename: d:\Program Files (x86)\WinSCP\WinSCP.com
2017-01-16 08:30:53.755   Time stamp of our file: 2016-11-30 13:57:12.000
2017-01-16 08:30:53.755   Dest file exists.
2017-01-16 08:30:53.755   Time stamp of existing file: 2016-11-30 13:57:12.000
2017-01-16 08:30:53.756   Installing the file.
2017-01-16 08:30:53.776   Successfully installed the file
I checked WinSCP.com and It announces itself as:
WinSCP, Version 5.9.3 (Build 7136)
Copyright (c) 2000-2016 Martin Prikryl
So WinSCP.com thinks it is the latest version.
The Explorer details tab of WinSCP.com show:
Date Created 11/25/13 5:32 AM
Date Modified 11/20/16 1:57 AM
The APPCRASH is still occurring, and still shows:
Problem signature:
So, my assumption is that the version is somehow miscoded in the WinSCP.com executable.
Thanks.
Thanks for your major donation!
AvalonNYC
I had a mistake in my script (I had omitted the credentials from the login), and the problem is solved.
Thanks for your help and thanks for WinSCP!
John Wilson
