call command
fungkw
call command
I am new to write winscp script. I want to execute a sh script in my winscp script like:
cd /folder
call ./batch.ksh parm
but it returns "500 "./BATCH.KSH PARM "
Then, I try the terminal feature in WinSCP GUI.
I enter command df and it returns:
500 'DF': command not understood.
It seems that winscp change everything after "call" to capital letters.
fungkw
Thanks.
But how about the second part of my question?
I tried "df" or "ls" but the console changes the commands to capital letters and said "command not understood"?
The terminal window of WinSCP is functionally equivalent to the call command.
So again, you cannot execute shell scripts with FTP protocol.
Btw, it's not WinSCP that converts the commands to upper case. It's your FTP server. But that's irrelevant to the actual problem.
