Downloading long file name files
JustAsking
I know that there is some sort of issue with WinSCP downloading long file names from within Powershell as I have seen a number of reports on this. I am using the latest version. The typical error I get is:
Failures : {WinSCP.SessionRemoteException: Can't create file 'c:\Directory\InProcessPC\AB1701090015040110.999'.
System Error. Code: 3.
The system cannot find the path specified}
BUT I can sometimes get this to work.
The following works to pull down the very same sets of files that fail to come down under more complex situations (generating the above error):
$session.GetFiles( $filemaskDown, $localPath, $false ).Check( )
Well it appears to work some/most times. It seems to work until it doesn't?!?! It is like my Powerscript code gets to a level of complexity and BAM starts generating those errors. I am using Powerscript 4 (Win7) and 5 (Win10). Anybody got any ideas?
Is it the name of the file that is the issue or the individual path components? What is the "limiting" issue? I could always temporally rename each server file shorter, download it and then name it back to what it initially was named, correct? Would that get around the issue?
Thoughts? Thanks.
JustAsking
Continued...
OK, just tried renaming the file to a 8.3 length, and then downloading and same issue.
Failures : {WinSCP.SessionRemoteException: Can't create file 'c:\TmpDirectory\InProcessPC\working.txt'.
IsSuccess : False
JustAsking
OK, worked around...
Not pretty but managed to code a work-around.
I get a listing of the files on the remote server and one by one:
- I rename each file to a short-name
- download the file to a short directory
- rename the file back (in production the file will be removed but for testing, this is easier)
- move-item the file to its final resting place while renaming it back to its original name (from the server)
It works but... :oops:
Re: Downloading long file name files
JustAsking
Here you go...
  • winscplog.txt (15.83 KB, Private file)
Does the local path c:\PayConcierge\InProcessPC exists? Can you browse to it in WinSCP GUI? Can you download the files to that folder in WinSCP GUI? What is a local file system of the path?
Yes to all. I can see the directory structure in WINSCP GUI and I can transfer those exact files without error. I performed the manual transfers as binary and as ASCII.
Please attach a log file from GUI showing an upload of file c:\PayConcierge\InProcessPC\CX1609271430050108.999.
Wait...
I may have found a Powershell script "bug" that was causing this issue. Am still investigating and will post my results either way.
