How Can I Upload without Dialogue Prompts?
Richard_D
I have just upgraded to WinSCP 3.7.6 and from Win 98SE to XP Pro. Previously, I was able to simply drag files from local folders and drop onto my remote web server as a one-step process; but I am now getting a 'Copy Dialogue' box before each transfer. Is there any way to turn off these dialogues so that drag and drop transfers will happen without further prompting?
TIA,
Richard_D
Cin
There is a way, go to Options > Preferences. On that dialog is a list of check boxes. Just make sure the appropriate boxes are ticked, ie. overwrite, etc.
Richard_D
[quote="Cin"]There is a way, go to Options > Preferences. On that dialog is a list of check boxes. Just make sure the appropriate boxes are ticked, ie. overwrite, etc.[/quote]
Got it! Thanks so much, I don't know how it missed this, it was right under my nose. :|
Cin
No problemo. The copy dialog annoys me to. :P
I have v3.7.6 and I have this problem too. I unchecked every box under preferences --> confirmations, but when I right-click a file and use 'send to winscp' and choose the session, I am STILL getting the copy confirmation box coming up. very annoying, help??
cheers,
-Trev
How else you want to specify target directory?
