script file work with bat file, but hangs when started with vba shell
georgewolfe3
NYC
SCRIPT:
open ftp://password:username@hosted.datascope.reuters.com/reports/
get 20170104_AGIGL_CLOSE.csv
Close
BATCH file:
winscp.com /script="datascope_get.txt" /xmllog="datascope_get.log"
VBA CALL:
Dim retval
retval = Shell("cmd.exe C:\Users\George\Dropbox\SNETWORK\WINSCP\datascope_get.bat", 1)
None of versions of the above code solve the problem. The above opens a command window showing the following:
Microsoft Windows [Version 10.0.14393]
(c) ms ...
C:\Users\George\Dropbox\SNETWORK\WINSCP>
Reply with quote E-mail
Re: script file work with bat file, but hangs when started with vba shell
Your command is wrong. Try in on command-line. It won't work either.
You are missing a /C switch after the cmd.exe:
retval = Shell("cmd.exe /C C:\Users\George\Dropbox\SNETWORK\WINSCP\datascope_get.bat", 1)
