File Not Transfering
sharda
This is a wonderful application and excellent documentation.
WinSCP Version 5.9.3
OS : windows 2012
We are using SSIS script task to upload file to server using SFTP protocal.For 2 SFTP servers, the file upload works perfectly.
But for one SFTP server it uploads a file of 0 bytes.
Attached are Session and debug logs. It appears that SSH_FXP_WRITE does not occur.
I used the Winscp GUI and it is able to upload the file to this server. I am using the same account to run the package as in the OS login session.
So i am a loss as to the cause of the problem. Please advise what i can try.
Thank you,
Sharda
  • sftpissue.zip (10.2 KB, Private file)
Re: File Not Transfering
The file seems to be empty:
. 2017-01-04 08:30:41.460 File: 'e:\test\dest\FileName.zip' [2017-01-04T13:30:38.664Z] [0]
If it is not, attach a log file from GUI showing an upload of the same file.
Also make sure that the local account that runs the .NET assembly code has a read access to the file.
ssharda
Race conditions
Thank you so much Martin. That was hint I was looking for. It was a race condition. Prior to the sftp there was zip task and it was running in a separate process. I put a delay in the sftp and now everything works perfectly.
Thanks again
Sharda
