is it true that every access with wincip just includes a terminal-access too
openSuseman
hello dear all,
first of all . many thanks for the great winscp. on a sidenote;: it would be great if you offer this for Linux too!!
today i have some issues - with my webserver. got an error Error establishing a database connection
i am wondering if anyone can help? i have access to the server via
webmin
winscp
filezilla
question:
On winscp there is an option located under the session link called 'open terminal' If i click that, i guess that i have access to the server.
well - if so: then i can login to your server using login and password
If i have a successfull login, reboot the VPS: shutdown -r now
then i cross my fingers - cause that all the services start again
question: is it true that every (!!!!!!) access with wincip just includes (!!!) a terminal-access too!?
love to hear from you
openSuseman
hi there
here some more insights!
unfortunatly the server does not allow the access.
ps - keep up the great work - it rocks.
btw: a linux-version would be great!
Re: is it true that every access with wincip just includes a terminal-access too
That's a very vague question.
As you have found out yourself, existence of the "Open Terminal" command does not guarantee you that the command works. The server must allow terminal/shell access in the first place. Does that answer your question?
