Create remote directory
laoho
I downloaded sFTP .net 5.9.3 and i tried to create a directory sFTP as documentation
foreach (FileSystemInfo fileInfo in fileInfos)
                        string remoteFilePath = session.TranslateLocalPathToRemote(fileInfo.FullName, localPath, remotePath);
                        if (fileInfo.Attributes.HasFlag(FileAttributes.Directory))
                            // Create remote subdirectory, if it does not exist yet
                            if (!session.FileExists(remoteFilePath))
                                session.CreateDirectory(remoteFilePath);
but i got an error:
SFTP protocol violation: Invalid response message type (0).
Error creating folder '/xxx'.
Any body help me pls ?
Thanks you
Re: Create remote directory
Can you create the directory in WinSCP GUI? Or using any other SFTP client?
