ignore failure and return status code 0 when no file is there at SFTP
DaveKalra
I have three different sftp location where file is coming at specific time .job runs vbscript which runs winscp commands to download files from three different SFTP location .when there is no file at sftp location then job gone to long execution state because status code 1 is coming from vbscript .I want to return status code 1 so that other instance will run .I tried to handle this situation in vbscript but cant do it.Help is really appreciated
DaveKalra
Hi Martin need your help to resolve this type of issue
Makc666
MSK-RU
No one will help until will see the script.
I don't understand why you can't make a code which will look if there any file on the host and if "No" go forward.
DaveKalra
c_commandStr = """C:\Program Files (x86)\WinSCP\WinSCP.com""" & " /command "
c_commandStr = c_commandStr & chr(34) & "open sftp://" & m_strFTPLogin & ":" & m_strFTPPassword & "@" & m_strFTPAddress & chr(34) & " "
c_commandStr = c_commandStr & chr(34) & "cd "& m_strFTPRemoteFolder & chr(34) & " "
c_commandStr = c_commandStr & chr(34) & "option failonnomatch off" & chr(34) & " "
c_commandStr = c_commandStr & chr(34) & "get -delete -nopreservetime " & m_clientFileName & chr(34) & " "
c_commandStr = c_commandStr & chr(34) & "close" & chr(34) & " "
c_commandStr = c_commandStr & chr(34) & "exit" & chr(34) & " "
c_commandStr = c_commandStr & "/log="& m_strLogPath & "sftp_" & ArgObj(0) & "_" & "Tabb_" & m_filedate & ".log"
This above code always return status code 1 when file is not available .added code "failonnomatch off" but log didn't return status code 0
DaveKalra
ignore failure and return status code 0 when no file is present at SFTP
Hi marc need your help to resolve the issue
Re: ignore failure and return status code 0 when no file is there at SFTP
The piece of the code you have posted does not explain, what problem you have with continuing on another server.
Makc666
MSK-RU
Try to replace
with something like:
  • move all files to another directory which is only for your operations
  • then try to get files from that another folder them without -delete
  • then make rm * on that another folder
