Can't launch PuTTY in ConEmu anymore (wrong position of "-load" argument?)
CherryDT
I am launching PuTTY inside ConEmu. To achieve this, my PuTTY application path is set to:
"c:\Program Files\conemu\ConEmu64.exe" /cmd "C:\Program Files (x86)\PuTTY\putty.exe"
This worked perfectly for a long time. I was last using version 5.5.6 (build 4746). Then I updated to version 5.9.3 (build 7136) and it stopped working.
I get the following error:
ConEmu 161206 [64]
Unknown switch specified:
-load "WinSCP temporary session" /cmd "C:\Program Files (x86)\PuTTY\putty.exe"
Visit website to get thorough switches description:
https://conemu.github.io/en/ConEmuArgs.html
Or run ‘ConEmu.exe -?’ to get the brief.
OK
Apparently, WinSCP now injects the -load argument between application path and the first parameter I define (which would be /cmd) and hence breaks the command line. I haven't found any way to change this. Am I doing something wrong? It would be great if the -load .... argument would just be another pattern, e.g. !L, so I could put it where it belongs...
Thanks!
PS: I'm running Windows 10 Pro Build 14393.576
Makc666
MSK-RU
The only thing about -load I was able to find in docs is here:
https://winscp.net/eng/docs/ui_pref_integration_app
If pattern !@ is not used, parameter -load <site> is automatically added to the command.
https://the.earth.li/~sgtatham/putty/latest/htmldoc/Chapter3.html#using-cmdline
In order to start an existing saved session called sessionname, use the -load option (described in section 3.11.3.1).
https://the.earth.li/~sgtatham/putty/latest/htmldoc/Chapter3.html#using-cmdline-load
CherryDT
Well, I don't want to use !@, !U, !P because I am using private keys which should be set correctly, also I don't want to do a hack like using !@ but in some ignored parameter or so and then manually adding -load "WinSCP Temporary Session" because WinSCP selects existing sessions if possible, so it wouldn't always be hardcoded to WinSCP Temporary Session...
It looks like in the past, the -load was appended at the end of the command, which works great for such a scenario (albeit less flexible than with a dedicated pattern), but in the current version it's inserted at the beginning of the command line after the application name, which breaks ConEmu or any other "prefixed" command like this...
Makc666
MSK-RU
CherryDT wrote:
Well, I don't want to use !@, !U, !P because ...
And this one?
https://conemu.github.io/en/NewConsole.html
Or, from your shell prompt (e.g. cmd.exe started in ConEmu) you can start PuTTY (or any other simple GUI applications) in the new ConEmu tab (or split):
PuTTY.exe -new_console -load "yourserver"
P.S. Can you tell me, how do you execute ConEmu64.exe?
When you say that you start:
it sounds like you start it from the .bat file.
In that case I hardly believe that it then changes to:
"c:\Program Files\conemu\ConEmu64.exe" -load "WinSCP temporary session" /cmd "C:\Program Files (x86)\PuTTY\putty.exe"
somewhere.
I don't see WinSCP involved anywhere?!
CherryDT
I am talking about setting it as path in WinSCP for PuTTY (similar to how the WinSCP docs suggest running WSL SSH instead). Under "Applications" in the settings.
About -new_console: It's a ConEmu-interpreted parameter to start a command in a new console, so it works when run from a shell which runs inside ConEmu already... Chicken and egg issue: WinSCP is not running in ConEmu ;)
And it does change:
Re: Can't launch PuTTY in ConEmu anymore (wrong position of "-load" argument?)
Thanks for your report. I'll try to find some good solution.
