Edit multiple files
muffinresearch
Edit multiple files
It would be great if it was possible to edit multiple files using WinSCP. Currently if I select a load of files and then right click and select 'edit' I only get one file loaded into the editor.
Cheers,
Stuart Colville.
https://muffinresearch.co.uk/
muffinresearch
Cheers Martin - will it ever be possible to open edit than one remote file or is this too difficult to implement/Not a necessary feature?
A workaround is to download a directory and work on multiple files locally and then upload the whole lot. So I can live with it how it is : ).
I suppose that you want to have option to open all file that are selected at once. Do you? Otherwise I must again repeat, that you CAN have multiple remote files opened at the same time, but not using "one click". Do we understand each other?
grobyc17
Re: Edit multiple files
You can edit multiple files, but you have to open them one by one.
why not open multiple files on single click? was it difficult to implement?
BTW, nice software!!!
May not be difficult. But definitelly it is additional work that I've decided not to do unless someone asks. Once you have asks, I can reconsider it :-)
grobyc17
yes, add me up! thanks! :D
