Connection problem: Login screen stays at the top
kamran
I am WinSCPing into an Arduino Yun, I cearly see it authenticates , does not give any error then immediately goes back to login screen. I can successfully connect with putty to the device.
I appreciate any help? Thanks
Re: Connection problem: Login screen stays at the top
kamran
Thanks here is the file
  • WinSCPA93Ctrace.zip (187.56 KB, Private file)
