Corruption on download
sam_a
Hi - I am switching from FTP Voyager to WinSCP. Great program!
However, my files are getting corrupted on download.
Any php file I download, and then upload, gives me the following error:
Parse error: parse error, unexpected T_CLASS in homepage/test.php on line 1
If I upload a version of the same file previously on my computer, all is well. Download seems to be what's messing it up.
Any ideas?
Thanks!
Sam
UPDATE: I've tried switching between Text,Binary and Default. No effect. Downloads are still being somehow modified or corrupted.
Re: Corruption on download
Can you check what had happend to the file during the transfer? I.e. compare the original and the uploaded file.
sam_a
The files appear fine. I can't see any change.
But sure enough, the problem is consistent, even after uninstalling and reinstalling the software.
I also tried the same files with several other FTP programs. The problem only exists with WinSCP (my favorite).
I'm wondering if there's some setting I'm missing. But all I could think of was text vs binary download. But that's clearly not making a difference.
But, there must be difference. Otherwise you would not have the problems.
sam_a
Yeh, there's no visible difference.
But if I try to view the page after download then upload it gives me an error. If I simply upload a copy already archived on my desktop, the file is fine.
This suggests to me upload is fine, but that download is messing something up.
Sorry I can't be more helpful. But clearly there's a problem with a default setting, or the program itself, with downloading.
Maybe some invisible? :-)
Are the sizes of the archived and downloaded files the same?
