Option when creating a new connection to keep local directory
Tradavo
Denver, CO
Often I have to push files to a number of different sites, all from the same source directory.
It would be really cool when the connection dialogue comes up to have a checkbox or some such mechanism so that when the connection is made to keep the current local directory. Would be a really nice time saver for me.
Thanks..
Re: Option when creating a new connection to keep local directory
You are possibly looking for an option Panels > Local > Do not change state when switching sessions.
https://winscp.net/eng/docs/ui_pref_panels_local
Thanks, I have used the option to restore or keep the directories between sessions. I will try this as I think it does the trick for me. You have a great product here. Really well designed.
