Double buffered internal Text Editor
Generic
I know that its possible to set any other external text editor.
But it would be nice if the internal text editor could be made a little more fluent in scrolling.
When scrolling trough large configuration files it sometimes feels a little clumsy.
Also the leftclick + scrollwheel operates the zoom factor. This makes it difficult to select and scroll at the same time.
I realize that there are much more important things to implement, but it would be nice if the internal text editor could get some refurbishing.
Re: Double buffered internal Text Editor
It might be something specific about your devices.
For example, for me the Ctrl+Scroll does not zoom.
What system/devices do you have?
Generic
It is LeftClick + Scroll that zooms, but that is a side matter.
My main point was that the text editor doesnt feel smooth and feels like its having difficulty scrolling trough large files.
For example, open a text file with a lot of lines in it.
And use the scrollwheel to scroll down fast.
Now do the same with windows notepad or notepad++ it is a lot smoother.
Sometimes the internal text editor is not done scrolling while i already stopped moving my mousewheel
So do you actually want to make the internal editor to scroll by lines, instead of the fluent scroll?
Because I read your first post to say the opposite.
Generic
I am trying to find how i can explain what i mean.
The fluent scroll, is not fluent enough when fast scrolling with the mousewheel.
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
