File Copy Error
File Copy Error
Hi!
I'm having a problem copying files from a Unix machine to a Windows machine for backup purposes. It works fine using the WinSCP GUI interface, but runs into trouble when scripting it. Here's the contents of my bat file:
winscp3 /console /script=C:\Scripts\backups.txt
Here's the contents of backups.txt:
option batch on
open xxxxx@xxx.xxx.xxx.xxx (hidden for security purposes)
cd colorado1/current
option transfer binary
get * E:\Misc Data\linux_backup\colorado1\current
close
Here's the output when I run the script:
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\>winscp3 /console /script=C:\Scripts\backups.txt
batch on
confirm off
Initialisation...
Searching for host...
Connecting to host...
Authenticating...
Using username "xxxxxx".
Authenticating with public key ""
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] xxxxxxx@xxx.xxx.xxx.xxx
/backup/colorado1/current
transfer binary
conf.tgz | 0 kB | 0.0 kB/s | binary | 0%
'E:\Misc Data\linux_backup\colorado1\current' is not file!
Session 'xxxxxxx@xxx.xxx.xxx.xxx' closed.
No session.
The line"'E:\Misc Data\linux_backup\colorado1\current' is not file!" is the error...it works fine if I just copy the files to the root of the E:\ drive, but it errors out if I try to copy the files to a sub-directory. Maybe it's just a syntax problem...any ideas about how I can fix this?
Thanks,
Donnie
Re: File Copy Error
Correct command would be:
get * E:\Misc Data\linux_backup\colorado1\current\
Note the backslash at the end. Read "help get".
Thanks! The slash at the end, plus putting the whole path in quotes solved the problem. I appreciate the response to a dumb question.
Donnie
