New Features request
jimmyp3
First i have to thank you for this great piece of software of yours that helps many people handle with ease ftp related tasks. I decided to contact you in order to request from you to add two new options in the "Find Files" utility that would be very handy for administrative purposes. I list them in the following lines :
1.
add a checkbox that will enable using a reliable hash code algorithm
the calculation of file verification hash code for each of the files
being searched and display an extra column with the hash value
next to the filename. I would like to use this feature to reliably
locate exact copies of files that could be uploaded on a server under
different names and paths and be able to delete redundant copies of
them saving valuable disk space.
2.
add another checkbox that will enable file search filtering by date
uploaded using "start date" to "end date" input texboxes and display
only those files uploaded between the two dates.
Thank you very much.
Re: New Features request
jimmyp3 wrote:
1.
https://winscp.net/eng/docs/library_example_find_duplicate_files
2.
https://winscp.net/eng/docs/file_mask#size_time
