Windows 10 Application Compatibility | Martin Prikryl WINSCP v4.1.9.416
salekin.ansari@...
Hello Team,
We are, Citi Application Readiness Team, need your assistance in order to gather info about below application compatibility and support for Win 10 as part of Window 10 Readiness initiative. CITI Bank has been using below software currently on Win 7 operating system and Citrix 6.5.
We would like to know whether the below listed application is compatible and supported even for Win 10 (64 Bit) or is there any other higher version of application which would be compatible for Win10. If you have not tested for Win 10, could you please provide us with a tentative date by when we can reach you.
Application Name : Martin Prikryl WINSCP v4.1.9.416
Thanks in Advance
Salekin
Citigroup Inc.
+91 22 3930 3341
Re: Windows 10 Application Compatibility | Martin Prikryl WINSCP v4.1.9.416
In general, there's no reason why WinSCP 4.1.9 should not work on Windows 10.
But it's over 7 years old version that uses deprecated encryption algorithms and should no longer be used!
Use the latest version of WinSCP.
