Move problem
arifoktay@...
Move problem
Firtly I'm sorry for my bad english. I use winscp 5.9.2. When I open winscp on desktop shortcut, I see all my session first screen. There is no problem so far. But I move this screen a little bit, The bottom screen it's getting too far on the screen. I hope I can tell.
Thank you
Re: Move problem
Sorry, I do not understand the "The bottom screen it's getting too far on the screen".
Do you mean that the main window is moving more than the Login dialog?
arifoktay@...
Re: Move problem
Yes,Exactly
When I move Login screen little right , main window move right more
Description: MAIN SCREEN MOVED VERY RIGHT
Re: Move problem
