Script successfully executed but files does not reach destination
serverman79
Asia
I have ran a script to copy files from my windows server to SFTP server, it worked and transferred files in the beginning stage but now it does not seems to copy over the files even though the command completes successfully and i can see the file transfer take place.
my script
option batch continue
open sp66
lcd U:\Y3_362_out
cd /incoming/mycompany/uat/my/export/
put *.xml U:\Y3_123_out
Exit
appreciate your kind advise
Re: Script successfully executed but files does not reach destination
This is not correct: put *.xml U:\Y3_123_out.
The U:\Y3_123_out should not be there. Use just put *.xml.
serverman79
Asia
Hello MArtin,
Thanks for the input it works fine now with put *.xml.
for some reason when i first tested the files got transferred without any issue , its really strange but i accept the logic.
Many Thanks for your kind help. :D :D
