ActiveX Automation - Can't create object
CarBor
Karlskrona, Sweden
Hi all! I'm probably missing something simple here but I can't get my VB Script to create the objects I need to do a file transfer.
I've installed WinSCP-5.9.2-Setup.exe.
I've registered the 23-bit and 64-bit tlb's. No issues...
I have a reference to the WinSCP scripting interface .NET wrapper (1.3). - I THINK this might be the issue. That's the only reference that shows up. I can add the tlb's by browsing but they won't stick...
I copied the code samples like:
Dim SessionOptions as WinSCP.SessionOptions
but the only way I can get all the options etc to pop up is by writing
Dim SessionOptions as WinSCPnet.SessionOptions
I haven't been able to find a WinSCP to download - only a WinSCPNet... What am I doing wrong, please?
Oh yeah, I'm running the scripts on a 64 bit Windows Server 2008 R2 Std, btw...
Cheers/Carl
Re: ActiveX Automation - Can't create object
Where do you have "reference to the WinSCP scripting interface .NET wrapper"?
What error do you get, when you "create the objects"?
