405 Method Not Allowed
paslechoix
Canada
I just installed WinSCP and tried to log in to a server I have privilege, I received an error saying:
Failed to list directory '/'
What I can do is using browser to log in to the site, and navigate to the folder that I have privilege and download files from there.
Am I missing anything here? is it possible to indicate the folder that I have privilege when creating login info for the session?
Thank you very much.
Re: 405 Method Not Allowed
How do you "navigate to the folder that I have privilege" in browser, if you do not have privilege to its parent folder?
I face the same when I want to login through WinSCP, I face the same problem:
405 METHOD NOT FOUND
Can you please help on this.
@Guest: Please start a new thread and attach a full session log file showing the problem (using the latest version of WinSCP).
Aditya
Just check the port number or credentials. This error is due to wrong connection settings
