ini file being used by another porcess
Moji
When I execute winscp script, I am getting this.
Can't create file 'C:\winscp\winscp.ini'
The porcess cannot access the file because itis being used by another process.
The error occur only when a lot of scripts are running together. If one or two scripts are running together is ok.
Please help me to resolve the problem.
Thanks!
Re: ini file being used by another porcess
In general you should not rely on external configuration in your scripts.
To isolate your script from any configuration, use /ini=nul command line switch:
https://winscp.net/eng/docs/scripting#configuration
If you really want to use an external configuration INI file (though again, you should not), set the INI file read-only to prevent WinSCP from trying to update it.
https://winscp.net/eng/docs/config#ini_readonly
moji
We set the INI file read-only. It works. Thanks for your help.
