-filemask for rm & rmdir
Pavel
Hi!
Scripting functionality will be more complete if you add an -filemask option for rm and rmdir commands.
Thanks in advance!
Pavel
Re: -filemask for rm & rmdir
Pavel wrote:
I need something like rm *.7z<2016-10-28
...and it works!
Ok, and how to work with directories?
This is fails: rmdir *<2016-10-28
The rmdir does not support masks. But you can use the rm to delete directories too.
pavel
Does rm supports a directory mask?
Something like rm */<2016-01-01 (this comman fails)
No the */ has different semantics here, than in a file mask.
But */<2016-01-01 works and will delete even the old folders (but files too).
Pavel
Ok, I see two ways: first is to add a full support for a directory mask semantic in rm command, or second is to add a masks support for rmdir. The first in my opinion is more correctly, and the rmdir command is redundant.
