Powershell - SynchronizeDirectories - The argument is null or empty
Kilsgaard
Silkeborg, Denmark
Hi
Can anyone give me an idea how to solve this?
I get the following error when i syncronize to or from my ftp with a powershell script, build on the template.
"The argument is null or empty. Provide an argument that is not null or empty, and then try the command again."
It looks like it is when there is no files to syncronize, but should: $synchronizationResult.IsSuccess be $false if there is no files that have been syncronized?
I am using the $synchronizationResult to move or removed syncronized files.
Can anyone tell me if there is any other trick to test if the $synchronizationResult is empty?
try
    $transferOptions.FileMask       =  "|*/"
    $transferOptions.OverwriteMode  =  [WinSCP.OverwriteMode]::Overwrite
    $transferOptions.TransferMode   =  [WinSCP.TransferMode]::Binary
    $synchronizationResult = $session.SynchronizeDirectories(
    [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $False, $False, [WinSCP.SynchronizationCriteria]::None, $transferOptions)
    if ($synchronizationResult.IsSuccess -eq $true)
       foreach ($download in $synchronizationResult.Downloads)
Thanks on advance
/Graves
Re: Powershell - SynchronizeDirectories - The argument is null or empty
Where do you get the error? On what command? Is this really a full error message? Doesn't it name the argument?
I cannot reproduce the problem with your code.
Where there are no files to synchronize, the IsSuccess is $True.
Kilsgaard
Silkeborg, Denmark
Hi
Thanks for your answer :-)
I have solved the problem, it was one of the winscp variables that I accedentialy set to an empty value :-(
