Moving Files to New Directory After Successful Upload
JimmyFree
There is a script that permits Moving Files to New Directory After Successful Upload. It is here: https://winscp.net/eng/docs/script_local_move_after_successful_upload
When I run it, it reports success, but the file never shows at its destination.
When I transferred using the GUI, it said it was successful, but had an error because it could not set the timestamp. When I turned off preserving timestamp in the GUI, then transfer worked.
How do I modify the above script so that it turns off setting the timestamp?
THANKS!
Re: Moving Files to New Directory After Successful Upload
What destination? The local folder or the new remote folder?
Your duplicate post:
https://winscp.net/forum/viewtopic.php?t=23946
