Some suggestions for the up coming version
Yang Dong
1. The useless remote path combo:
I definitely believe this combobox is of no use at all, only occupying the valuable screen space, please remove it.
2. We can put the 'File..' menu item to a better place
3. File window suggestions.
4. Again, I suggest we can provide the filter combo edit directly in tool bar, not in a dialog.
Description: The 'File' command can be put outside of the menu, direct in the toolbar.
Description: The useless combobox
Re: Some suggestions for the up coming version
Do you know, you can shrink it by dragging the toolbar next to it to the left?
For now, it's easier to open the filter dialog, by clicking the filter in the path display:
https://winscp.net/tracker/1478
I can send you a development version for testing.
