filemask for several file type
Rirbeiro
Brazil
Hello
I'm getting in trouble using filemask with the command line to download several file types in last one hour.
with the command below it get all files and not follow the rule ">1H"
get -filemask=""*.xml;*.pdf>=1H"" /vv447Q/pdfdanfe/* C:\pdfxml_totvs
Thanks in advance
Re: filemask for several file type
The time-constraint is a part of a specific mask only, not whole set of masks. So you have to repeat it with each mask:
get -filemask=""*.xml>=1H;*.pdf>=1H"" /vv447Q/pdfdanfe/* C:\pdfxml_totvs
Rirbeiro
Brazil
Hi Martin,
I follow your commands but all files were copied and not just the last files modified in the last hour.
Another questions is: Can I use "synchronize local" instead "get"?
Thank you in advance,
Not sure what your question is about. These two commands have a different semantics. So use the one that fits your needs better.
Hi Martin,
I have modified my script as below and it is working very well:
"synchronize local -filemask="*>=30N" C:\pdfxml_totvs\ /vv447Q/pdfdanfe"
Thank you so much.
