Help With Automation Script Please
merlinbrent
UK
I have this script...
open ftp://user:pass@ftpserver.com/
cd /
option transfer binary
get -latest *.*
close
That is supposed to connect to an FTP server, and download ONLY the latest file. Based on what I've read my syntax looks correct. But it doesn't work.
If I exclude the latest command and just use *.* this works fine, but downloads all of the files, when I only require the latest one.
Any help provided is much appreciated.
Martin
Re: Help With Automation Script Please
What does "doesn't work" mean? What does it do?
Are you using the latest version of WinSCP?
If you are, please attach a full session log file showing the problem.
merlinbrent
UK
No I wasn't using the latest version, my bad. I've downloaded the latest version and this seems to be working fine now.
Many thanks and sorry for wasting your time on this.
Martin
